Hi guys,
I just have a rather simple question for all of you of which I will put into a poll.
The question is as follows:
• How do you cool your CPU?
You may choose to comment but it's not necessary.
Cheers,
Geekazoid
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/124150-cpu-cooling/
currently a 212 evo next build may be a custom loop 350d just depends how the new intel mobos play out and if i still love the 350d
Specs
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651585
I have a custom watercooling loop for my 3930k.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651586
I just bought an H100i and I'm going to install it this evening :)
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651588
Good on ya. I hope it all goes well and you don't end up water submerging your rig. :P
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651597
I found the line method worked best for thermal paste on my old FX CPU. The pre-installed thermal paste caked up in about a month from the heat output of FX.
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651620
you should put options for custom watercooling and aios.
It's just a general question.
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651624
Why water cooling is water cooling...
As for me I am running a locked overclocked CPU on stock cooling woo! And according to every temp monitoring software it also runs at 105 degrees.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651705
My friend, @ScottS1 's A10-6800K's GPU runs at -8°C according to every temp monitoring software.
Meanwhile the CPU cores run at about 60°C.
"Everybody wants a happy ending, right? But it doesn’t always roll that way." - TS
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651751
I knew at least one person would pick c)...
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651809
I added A, B and C to each option to help people realise what you're referring to. :D
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1651819
Why, thank you sir! :D
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1652185
i would be interested.
amd temperature sensors are shit anyways.
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1652311
air. lots and lots of air.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1652541
Theres not much difference between air & watercooling. The difference comes down to the use of a pump to circulate the liquid.
Anyways I prefer air anytime over water, just attach the fan to a chassis fan and enable autofanstop in fan xpert 2 so the fan turns off at idle. Screw pumps really..
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1652810
Screenshot of CoreTemp (Imgur used as the photo didn't appear, I might just be stupid...):
http://imgur.com/0rI1oPp
I have an A10 7700K, not an A10-6800K and the bios reports 60°C...
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1653903
No worries. :D
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1654278
I have a H110 - definitely the best cooler I have ever bought. There are some problems with clearance and mounting though. The H105 is also a great option for a thicker 2x120mm AIO.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1654295
According to Linus thicker isn't always better. Just thought I'd mention that.
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1654333
It depends. If it is a thicker 120mm radiator compared to a slim one, the thicker will perform better if you have the money to afford some decent pressure optimized fans. Anyways, the H110 is a 2x140mm so yeah, it outperforms the thicker H105 (2x120mm) by a couple degrees.
PS: SLim rads will also benefit good quality pressure optimized fans.
https://linustechtips.com/topic/124150-cpu-cooling/#findComment-1654362
