There’s plenty of better cases with significantly better airflow
P400A, Meshify C, etc
3 minutes ago, rickschroemges said:
I was wondering if the NZXT 510 has some good airflow and if its durable. Because i saw some very positive reviews about this case and also some negative ones. so i was wondering what you guys were thinking about this case.
Thank you for the help! :)
It has decent airflow but it's not the best, there are far better cases for airflow at similar price points. The H510 is more of an aesthetic case
i would not call it decetn it does not even have airflow in my opinion
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
4 minutes ago, Som3a said:
it has a top intake and some perforations on the side, they aren't enough but I think it's more of a watercooling case
its not a top intake. its an exhaust and the case is design mostly for negative pressure. It handles air and water cooling poorly equally,
you can flip the fan and set it as intake, you're not limited by the manufacturers decisions
5 minutes ago, rickschroemges said:
For this build what would be a better case? and fans cause i want the same fans as the case for astatic. idk why :)
Don't have anything in mind right now but you can get something with a mesh front panel and get fans from the same manufacturer
p400a, p300a, meshify c, td 500, lancool 2 mesh performance.. Also the p14 fans are better than the NZXT AER
