Just now, luqiano02 said:
I have A i7-8700(NON-K) and I have A Noctua NH-U12s chromax.black. When I get into a game whether its A workshop map or a competitive My Cpu Temps are always between 60*C-70*C with 30% to 40% CPU Usage, Anyone know Why my temps are this high or Is it normal?
probably normal.... but have no idea what your system specs are yet, so don't quote me. :P
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971787
I Have A RTX 2060, Hyperx predator 3200 mhz and ROG STRIX Z390 Gaming MOB(I know its a motherboard for overclocking but I will upgrade my cpu to a K processor in the future)
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971790
Pretty normal temps, you could try stressing the cpu with an all core stress test like cinebench r20 test and check temps..
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971795
The 8700 is known to run pretty warm, so it's not really a horrible temp.
These chips where infamous for de-lidding and replacing the thermal paste under the IHS plate.
So your temps are normal imo.
What case? hows the air flow, good?
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971799
I stress tested it for 5 minutes in Intel Xtreme tuning utility and the highest temp was 85*C if I am correct
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971803
I have  the Evolveo Functio 2, I have 2 intake fans and one outake
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971808
Nice. Run the exhaust at higher rpm than the intakes will help dump the case heat better.
You want as much case heat out through the case fan so it's not pushed through the PSU.
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971818
I also have another Coolermaster Fan thats not in the case right now, You think i Should put it as Exhaust to help remove heat?
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971821
Try a full run of cinebench and check but again for the most part if those are under gaming loads, that's perfectly normal.
Build Log:
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971830
temps seem normal, if youre running high framerates in csgo itll push a lot of power through 1 or 2 cores
for comparison, i had a 9700k with a u12s on it and my all core temps on stock clocks were under 70C. case was the phanteks enthoo itx which has mediocre airflow.
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971837
Im looking to buy An I7-9700k in the future, is the cooling good with the u12s? And also thanks for the reply
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971854
Did you build this system yourself?
I'm no expert but if it was me I'd re-do the cpu cooler.
Take it off, clean the old paste off.
Put new on and reseat the cpu cooler.
If you have done that sort of thing before and feel comfortable with doing it of course?
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971861
really only for stock clocks, you should get something better for an overclock. my d15s was only sufficient for 5ghz with a high avx offset
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971876
A friend built it but my brother also knows how to put on the cooler, I recomended it to my dad an brother, but they were scared because on my older MOB we broke our Pins...
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971879
If i ever get it, I'm not thinking of overclocking it to let's say 5ghz, more like 4.7-4.8
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971883
Oh ok, then you should definitely not do anything you don't feel comfortable doing.
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971889
I did get some really high spikes in temperature while playing CS:GO sometimes, but 60-70C is perfectly fine.
That's a sidegrade from the 8700K though
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971890
5 minutes ago, luqiano02 said:
Or maybe I can wait a bit longer and go for the i9-9900k?
That'd be an upgrade, though I can't imagine the 8700 not being enough for gaming.. unless you do some other tasks that are more multithreaded.
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971912
Its enough for gaming lol, but ill upgrade it maybe in like a year or two
https://linustechtips.com/topic/1240608-high-cpu-temps-in-csgo/#findComment-13971921
