Used laptop.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/124021-300-dollar-build-help/#findComment-1650004
A netbook would fall in this price range, fulfill all your needs and be extremely portable. I love buying the parts and building myself but for this purpose I do think a netbook might suit you better. A Windows license (already installed in a netbook) is almost one third of your budget.
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
https://linustechtips.com/topic/124021-300-dollar-build-help/#findComment-1650052
Getting a build for you now.
This should do you just fine for that purpose. http://pcpartpicker.com/p/34V9M
is a nice build but the athlon x4 do not come with onboard GPU its only a CPU
AMD onboard GPU is only found in the A series APUs
a used Atom based netbook will be a better bet if you are really low on cash
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/124021-300-dollar-build-help/#findComment-1650074
Chromebook. They're cheap, fast, light, and do exactly what you need: Web browse.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/124021-300-dollar-build-help/#findComment-1650130
