Hello,
I’m looking for a case that dampens noise and has an okay airflow as well, be quiet series caught my attention but the small vents at the front won’t let inside enough fresh air. Do you guys have any recommendations for a modern case with a foam that is also pretty spacious up to 200$? Thank you so much^^
https://linustechtips.com/topic/1237485-recommendations-for-a-silencing-case/
I've heard that CoolerMaster Silencio cases are quite good, though I don't know if they would fit your needs.
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
Your ideal case is the Phanteks P600S.
It's a silence-optimized case with a quick-removable front panel for great airflow.
Also the included 3 140mm fans are more than enought to keep everything quiet and cool.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Rather than approach this topic with a case with foam, I recommend using a high airflow case with quiet fans. BeQuiet and Noctua are great fans for this.
The more sound-proof the case is, the less airflow it will have. The dampening foam doesn't do as much as you think it will, and what a lot of manufacturers have to do to 'sound dampen' a case is to limit where air can pass, because then it limits where noise can escape. The problem with this is that the less air that can pass in from the outside, the faster the fans run due to the cooling performance being crap.
If you have good airflow, the fans don't spin up as much, and don't have to work as hard, and aren't as loud.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
I have an i9 9900k with a high overclock cooled by a Dark Rock Pro 4 and in cpu heavy games it’s audible. My case fans are already pretty quiet that’s why I’m looking for a balance in between airflow and silence
Well if you are really looking for a case that is quite you should be looking for a case without glass side/front panels.
Also the quality of the case fans should be a top priority.
Be Quiet Silent Base 601 / Silent Base 801
Fractal Define 7
You should also consider which CPU cooler you choose.
You can't go wrong with Noctua in both performance and noise.
NH-U12S / NH-U14S / NH-D15
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
