Can we get a picture? Sounds like the BIOS prompt that asks if you'd like to save your changes before exiting.
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939665
2 minutes ago, TheBeast108 said:
Oh yes, here you go
Well the LL120's are pwm afaik and not DC.
If you didn't change it, you could switch it back to auto and then hit save.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939682
Just now, TheBeast108 said:
How do I do that in here?
Well these are fan curves for the fans.
Set it to standard for now then save after than save the settings in the bios.
Build Log:
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939698
1 minute ago, TheBeast108 said:
It’s already in standard
Then hit escape.
Hit save and done..
Build Log:
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939708
but I’m pretty sure it’s already in pwm mode
Well for now you could just hit save and exit and then check after you finish the build.
Build Log:
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939717
I’m taking that as I click ‘ok’ for it to change the fan from auto to dc?
Yes. As I said you could just click save and end.
Or you could reset the bios to default and then hit save and exit.
Build Log:
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939728
Click Cancel if it's saying it's going to change fans to DC.  Then go over to Exit at the top.  Then select Discard Changes and Exit.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1236366-do-i-click-allow/#findComment-13939783
