Budget (including currency): ~£800
Country: UK
Games, programs or workloads that it will be used for: CAD (Fusion350 and TurboCAD2015), Blender, Gaming
Upgrading from:
Intel Core i5-6500 @3.20GHz
16 GB of Ram
H110U Motherboard
NVidia 970 GTX Graphics Card
250 GB SSD
1 TB HDD
My proposed parts list for him:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£164.97 @ Amazon UK)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard  (£71.98 @ AWD-IT)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£62.35 @ Amazon UK)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  (£58.08 @ Amazon UK)
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB WINDFORCE OC Video Card  (£353.40 @ Amazon UK)
Case: Corsair 275R Airflow ATX Mid Tower Case  (£67.98 @ Amazon UK)
Power Supply: SeaSonic S12III 550 W 80+ Bronze Certified ATX Power Supply  (£53.60 @ CCL Computers)
Total: £832.36
Generated by PCPartPicker 2020-08-18 23:05 BST+0100
The questions are:
  • Buying a better motherboard to make upgrading to CPUs with higher current draw a viable upgrade path I think is worth it, so to go at least to Tear C so that he can get to a 3900X if he wanted to. Probably a B550 would be all he needed, rather than a 570. I'd need to research which is the cheapest in that tier.
  • He could probably leave off the nvme drive and just buy that later if need be.
  • I did consider the 5700XT but he's used to Nvidia and Blender, when last I checked, played better with the green team.
  • The 3600X seems like the sweet spot at the moment, so even though CAD would benefit from more cores, the cost per core goes up a lot from there.
UserBenchmark, if it is to be believed, has a decent boost:
Thoughts?
https://linustechtips.com/topic/1236000-build-for-a-friend/
25 minutes ago, dfsgsfa said:
3 months later new gen cpu and gpu come out and regret your life
dont pick that mobo, 2nd lowest model from each brand is miles better
get better ssd, NO QLC, NO DRAMLESS, full speed 3000mb+ for little more
GPU likely won't come out until late fall/early 2021, and the CPU won't see that much of an improvement and will cost more.
I doubt he'll be regretting much.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1236000-build-for-a-friend/#findComment-13936441
18 hours ago, lexusgamer05 said:
I think your proposed build looks good, I wouldn't change anything
You can do that if you want to but the 3600 will probably be fine for a long time
I looked up some Blender benchmarks, and for the most part, it fluctuates a bit, but here's the benchmark scores and you can make your decision
  Reveal hidden contents
Blender 2.83 GPU Rendering Performance - BMW (Cycles) Project (June 2020)
Blender 2.83 GPU Rendering Performance - Classroom (Cycles) Project (June 2020)
Blender 2.83 GPU Rendering Performance - Controller (Cycles) Project (June 2020)
Blender 2.83 GPU Rendering Performance - Mr Elephant (Eevee) Project (June 2020)
Also, don't use UserBenchmark, it's unreliable
Thank you, super helpful reply, both re UserBenchmark and the Blender benchmarks 👍
https://linustechtips.com/topic/1236000-build-for-a-friend/#findComment-13938829
What? A second lowest model from most companies don’t even have 1 vrm heatsink. At least this board does
https://linustechtips.com/topic/1236000-build-for-a-friend/#findComment-13939106
