My Lenovo Idea pad S145-15ikb stopped charging. I was just using my Laptop while it was charging and suddenly it got stuck on 95 per cent and this is what I was able to see. I tried everything but the last option left is to remove the battery but the problem is that i will have to remove the whole back cover of my Laptop. My charger is just working fine on another PC. 60177505_notcharging.thumb.PNG.a555030693f59fcf2be02d76072afe67.PNG
https://linustechtips.com/topic/1235815-plugged-in-not-charging/
I'm not that good with laptops but afaik some models do this to prevent the battery from wearing out faster.
wait until it drop a bit and then check if it charges again.
Phone: Pixel 3a (Purple-ish).
Build Log:
Because I naturally don't give two shits about my work computer, I never once looked at the power charge.
I decided to take a look at it. It has been plugged in for about 4 months now, and is also at 95% plugged in not charging.
Working as intended re: battery preservation.
"The more charge cycles a battery goes through, the lower its life becomes. ... If you see the Plugged in, not charging message after your battery reaches 95% charge, then it might be a driver limitation. Check if the battery still charges if it's at 50% charge. If it does, your battery is in good health"
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
