I need planning help, I will be waiting for the new gen to come out and maybe black friday but I'm unsure what to do on some parts
Current PC :
Mobo : Prebuilt shit
CPU : Core i5-8400
GPU : GTX 1060 3GB (Single Fan)
RAM : 2x16 corsair vengeance pro RGB
PSU : Will blow my house up
Case : Still prebuilt
HDD : 4TB 5400 RPM, 1TB 7200 RPM
SSD 128GB M.2 SanDisk
What I'm upgrading to
Mobo : Gigabyte X570 AORUS ELITE
CPU : Ryzen 5 3600 (Unsure)
GPU : GTX 1060 3GB (Keep / Unsure)
RAM : 2x16 corsair vengeance pro RGB (Keep)
PSU : Corsair CX650M
Case : Corsair carbide 200R
SSD 128GB M.2 SanDisk (Keep / Unsure)
Any feedback would help
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1235792-pc-help/
For upgrading, in my personal opinion the 'why?' of it all matters a lot.
For example, I see you are unsure or keeping the videocard. If this is a gaming system at above 1080p60Hz, I would definitely consider an upgrade in that territory, since it will make the most impact in gaming.
I would also consider getting a new higher capacity SSD (like the SX8200, A2000, etc. in 500GB+ capacities), to easily be able to install Windows + a couple games to the drive.
The motherboard is great, if not a little overkill though. CPU is a good value.
What speed is your memory at, by the way?
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934532
Current PC :
CPU : Core i5-8400
the motherboard is un-necessary for a 3600 , get something like a msi b550 gaming plus or a-pro for half the price
yes the 3600 is a bang for the buck chip
the gpu needs to be upgraded ,so just wait till august 30th for the release of rtx 3000 cards
the ram is good enough but wont be running at good mhz since its from a prebuilt
psu is awsome
get a better case with higher airflow , something like cooler master td 500 mesh or fractal meshify c
hdd: its according to your needs , ssd : get an another 500gb ssd and also keep the current ssd
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934538
Had the A2000 before had to refund it damn prebuilt mobo was SATA and not nvme
Forgot to say that 3200mhz
So 3600 is good go? The mobo I like it and a friend has it so I feel like it's good and won't need to be switched fast
Right now highest res is 1080p144hz considering higher in the future (also need the nvec encoding
6 minutes ago, minibois said:
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934554
The SSD is just something to consider (as 128GB is kind of minimal nowadays) and the memory would be fine.
3600 is a good CPU, for a good price.
The motherboard is also great (I also built a system with it in the past), it's just that you could go for a cheaper B550 board and spend this money elsewhere. Emphasis on could, because it's still a great board which indeed I don't expect you'll have to exchange in a long time.
Depending on the game, the GTX 1060 would probably still be fine.
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934566
but the mobo is overkill for your cpu , getting a msi b550 gaming plus or b550 a-pro will last you long and mind that it doesnt matter if it lasts long since amd has only given assurance that the am4 socket will last till 2022
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934567
RAM is new for it recently it's 3200mhz
10 minutes ago, alirafi321 said:
Get a better case with higher airflow , something like cooler master td 500 mesh or fractal meshify c
I really like this case and the airflow isn't to bad
Will be using the old ssd in another build
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934578
The price is almost the same here so it doesn't really matter with the x570
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934586
https://www.youtube.com/watch?v=NkuBK9jSvIE the corsair carbide 200r is all the way from 2012 , feeling old yet
I know it's old but I don't like the style of the newer cases
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934610
Some cases are timeless. Antec P180 was 2006, way ahead of its time, still looks modern today.
Antec P180B Performance One ATX Case - Bjorn3D.com
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934614
1 minute ago, alirafi321 said:
actually where ever u r living the x570 aorus elite is a high end board making it cost double a normal b550 which will run a 3600 extremely good
First of all did I say where I live or do you just know?
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934619
^^ This
9 minutes ago, alirafi321 said:
The corsair carbide 200r is all the way from 2012 , feeling old yet
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934623
^^ This
A case is very personal, but I don't like the Corsair 200R. I don't like the vents on top, unless you have upward exhaust fans or a 240mm radiator, that's just gonna be a dust trap. The 100R is a beautiful case with the same problem.
Tell us your location and budget and we can probably piece together a much better build, and work on finding a case that is both practical and meets your aesthetic preferences.
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934636
Also just saying, your current PC is just fine. A GTX 1060 will run absolutely anything at 1080p, and an 8400 is a modern six-core... Not sure why you wanna upgrade so bad.
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934642
Budget : Not sure tbh just don't want to spend a fortune maybe $600 or $700
Case will be getting an aio in the near future
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934647
It's having problems and just want to upgrade mobo and I thought let's take amd in the same stone
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934650
5 minutes ago, alirafi321 said:
so i believe u dont want a windowed side panel?
Since I'm moving it often no if I want one I will prob make one for the case
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934677
woah thats cre8tive
It really isn't when you think of it alot of people do it
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934694
Probs sticking with the GPU for a little longer
Changed to amd in the text BC autocorrect
Reminder⚠️
https://linustechtips.com/topic/1235792-pc-help/#findComment-13934744
