Using 3 monitors with different specs
Hey everyone, Im planning to use my 2k 165hz monitor as primary, 4k 60hz as secondary and 1080p 60hz as third. So since all the resolutions are different and refresh rates are different will my primary monitor refresh rate (165hz) get affected by the others at all? Can I use all monitors together without issues? Thanks
https://linustechtips.com/topic/1235725-using-3-monitors-with-different-specs/
Ii you plan to use them to improve your workflow, you can actually run them with different resolutions and refresh rates.
I'm assuming you're not talking about gaming
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
you can run them just fine. games will need to be configured to run on the correct display at the correct refresh rate, because with different displays and refreshes it sometimes won't detect correctly when you launch a game but once you set it manually it should be ok.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
38 minutes ago, redcan0 said:
I will be using this setup for gaming will the 165hz lock to 60hz then?
If you extend the 3 monitors this is your best case scenario. Without accounting for different response times, bezels, etc You should test it
But if you have 3 monitors hooked up you can still play the game on each one of them at their respective resolution and refresh rate.
I have a 144hz and a 60hz display, I can run my game @144hz in my main monitor, while using the second one for other tasks.
