Hi there quick question i need a good overclocking board to use with my 9900k. Im going for Z370 and not for Z390 as i have a good offering in two boards but just wanted to get an opinion on wich should i go for. Either the "ASRock Fatal1ty Z370 Professional Gaming i7" or the "ROG Maximus X Hero".
The ASRock VRM seems better on paper and has some nice features but the Asus one has bios Flashback wich means i wont have to borrow an 8th gen CPU
https://linustechtips.com/topic/1234348-help-motherboard/
looking at reviews I say no
go with the asus
actualy newegg broke on me
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922199
go with the asus since I can't find the asrock board
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922217
Just now, Diogo_01 said:
Yea cant find any decent reviews on it.
Thanks
I could not even find it on pcpartpicker
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922263
10 hours ago, Diogo_01 said:
ROG Maximus X Hero
the hero uses 8 sic639's in pairs (so 4).
as for the asrock board, i could not find anything about it's vrm sadly, if you're strictly limited to these, the hero will be more than enough.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922300
Are these your only options?
Why..?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922334
Maybe this helps
thats just marketing and could not find a seller that still sells it
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922583
1 minute ago, Diogo_01 said:
Maybe this helps
the asrock one is much better then. hero maxes out at 400A and the asrock one at 720A os the asrock one is much ebtter
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1234348-help-motherboard/#findComment-13922584
