55 minutes ago, linusasfani said:
hello,so i have asrock b75m-dgs version motherboard and also i have case with 4 rgb fans and i dont know where should i plug them,molex power connectors from psu or somewhere at motherboard?
  1. Motherboards dont have MOLEX connectors, PSU's do.
  2. RGB fans come with either 3 or 4 pin fan headers. Only ultra cheap budget fans ($2 fans) come with molex cables anymore.
  3. Plug your fans into your motherboard so you can control their speed. Use a Fan spliter or a fan controller because your motherboard only has 1 Chassis Fan header (below and to the left of the CPU socket)
https://linustechtips.com/topic/1234344-need-help/#findComment-13922343
