My First Build For Adobe Apps, Help me Getting the best out of $450
Budget (including currency): $400 to $450
Country: India
Games, programs or workloads that it will be used for: Adobe softwares
Other details
i3 9100f - $80
Gt 1030 2gb - $87
8gb 2666mhz (Single stick) :- $43
Msi B365m PRO-VD :- $86
Cooler Master PSU 80+ 450W:- $37
Case :- $43
Kingston SSD (240gb):- 39$
Thermaltake Air cooler :- $14
Already Have a 1TB HDD
This totals around $429
This is my first time building pc and my biggest personal investment ever, Help me to get the best of my low budget, Thanks
Country: India
Other details
i3 9100f - $80
Gt 1030 2gb - $87
Case :- $43
Try used maybe
2 minutes ago, YT_DomDaBomb20 said:
And maybe a gpu with more vram
I don't expect to be gaming at it much, Adobe Apps mostly rely on cpu, and only the exports and render needs gpu, so maybe 2gb is enough in the budget
5 minutes ago, Avocheeseado said:
Are you using them lightly? or doing heavy work on them.
$450 cant get you much new
Majority Photoshop, Illustrator and Lightroom and Some light work Premiere Pro, I had a AMD A3 before with integrated Radeon R5, pretty old hardware, and still it runs all Adobe app moderately.
10 minutes ago, YT_DomDaBomb20 said:
Try used maybe
Indians tend to resell at retail price or maximum 10% less than it, plus due to lockdown the public transport is at minimum
if you wanna save about 130 then take off gpu, but idk how vram would be then. ryzen would be better than intel considering you're not gaming and the intel one was an i3
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
750w dragon or something psu idk
