I made a fan 40mm housing to direct airflow into the motherboard chipset fan directly out of paper to see if my idea would work to cool it. I was getting a average of 85c on my chipset while playing games in a air conditioned room. the reson why is because my 3 slot gpu covers the chipset fan intake and blows hot air into it and i cant move it to any of the other slots because im using 2 other pcie devices. It works where now im getting about 73 while gaming so im planing on making a more solid and permanent version of this. my question is on what would be the best way of making a more permanent solution. Also if there is a better way to cool my chipset. My case doesn't have much space to work with as its a fractal define 7 compact and doesnt let me mount gpu vertically to move it away from the chipset fan intake
https://linustechtips.com/topic/1232610-x570-chipset-cooler-help/
4 minutes ago, Samfisher said:
3D print something?
I don't have access to a 3d printer and most online 3d printing companies seem to charge over 100. I'm trying to do this cheaply if possible since I don't have much funds to spend to fix this issue as I did this with stuff I had on hand already
A lot of x570 boards don't have thermal paste between the fan and the heatsink of the chipset.  Gigabyte boards I know you can remove the backplate, remove the thermal pad and apply your own thermal paste and have it drop 10-15c.  Keep the thermal pad for RMA.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
Would be good if you said what board you have honey.
Anyway, your problem is that th gpu is blowing the hot air right into the chipset. I would strip the chipset cooler down untill there's only the fan+heatsink lest and make a costum box from Microwave Plastic Container or duct tape the 2080 where the chipset is
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
im using a Asus crosshair VIII Hero and i already put tape on where the gpu would blow ait into the chipset and it didnt help then i used thermal tape and still didnt help. the space between the gpu and intake is really small like 5 or 6mm and all the surrounding air is hot since it coming out the gpu. ill see about putting thermal paste under there but i dont really have high hopes for that and dont want to void my warranty.
what abut a vertical gpu mount. it will let you be able to put w/e size fan on it and the gpu air would not blow in to it. if that dose not work then guess its bigger then you and me?
1 minute ago, Ritsukashy said:
My case doesn't support vertical gpu mount
what you mean? how may pci slots dose it have?
there a cheap one
rgb one
one that sits on the bottom of the case
