Posted August 9, 2020 Anyone knows of a good, safe and possibly free software that will allow me to view my computer's stats (utilization and temperature) from my Android Phone? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 Are you going to need to do this internally (within your own network) or externally (outside the network)? ask me about my homelab on a personal quest convincing the general public to return to the glory that is 12" laptops. cheap and easy cable management is my fetish. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 Author 1 minute ago, Skipple said: Are you going to need to do this internally (within your own network) or externally (outside the network)? Internally. I built a new PC last month and I just want to monitor it's stats while I'm playing Full Screen. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 Try Pulseway. I think its on android. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 i remember MSI afterburner allows user to monitor their PC stats on android not sure if that's still a thing or they stopped doing that -sigh- feeling like I'm being too negative lately Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 Author 6 minutes ago, McMonty said: Try Pulseway. I think its on android. It's properly rated, guess I'll give it a try. Cheers Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 Author 3 minutes ago, Moonzy said: i remember MSI afterburner allows user to monitor their PC stats on android not sure if that's still a thing or they stopped doing that That one is very badly rated on the Play store, so I think I'll skip over it. Thanks anyway. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2020 HWMonitor comes to mind. ask me about my homelab on a personal quest convincing the general public to return to the glory that is 12" laptops. cheap and easy cable management is my fetish. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
