is 100°C safe for mosfet?
Solved by mariushm,
The mosfets will be fine, they're rated for at least 125c, some are rated for 150c
Long term, it would be a good idea to get that down to around 95c ... over weeks and weeks of running at 100-110c the printed circuit board on which those mosfets are soldered will degrade from the heat ... but that's a long time, a few hours a day when gaming it's not a big deal.
You could just add a 92-120mm fan blow down on the heatsinks and that should get you a few degrees off.
