With this setup i seem to get way less fps than i sohuld be getting in almost all games.
leauge of legends for instance average at around 120 fps, while my gpu uses 20-30% usage and gpu 30-40%
I use a 2560×1600px monitor at 144Hz.
My friend uses a 1070 gpu on a 4k screen getting atleast 200 fps on average
My best guess is that there isnt enough power on my psu since my gpu uses 650W leaving only 100W for the rest of the system.
I have tried everything in nvidia settings high performance etc.
No vsync is enabled i do have gsync enabled(dont think that takes performance)
Recently removed geforce experience from my pc some people said that was an issue but no change.
I am using an updated bios
https://linustechtips.com/topic/1230409-my-pc-never-performs-max-usage-low-fps/
Your power supply is definitely not the problem. A 2070 recommends a 650W PSU but that's taking into account the rest of the system-- it's near impossible to cool more than 300W in a standard graphics card cooler, so very few cards will use more than that. Those recommendations are also from a time when power supplies were much worse and couldn't always deliver full power on the main rails, so it's a bit overkill.
I'd check drivers most likely, and make sure XMP is enabled.
Not quite sure your PSU would be the problem, a 2070S is rated to draw 215W and I doubt you'd be drawing over the rest with system. Have you tried stress testing and seeing if that gets your resource usage up? Checking your drivers would probably be the case if not. This might seem obvious, but have you unlocked your IG framerates?
Your system doesn't draw even half of 750W while gaming, and the Vengeance is a solid unit. The 2070 Super does not pull 650W btw, that's just what most manufacturers "recommend".
DDU your video drivers, install the latest from the GeForce website, then try playing both with G-Sync on and off.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
If you want to know how much power your GPU uses get GPU-Z and under Advanced/Nvidia Bios it will be displayed.
A RTX 2070 should be around 200 watts max with an overclock. The number can vary depending on the silicon and cooler.
If you want to see your max power usage. Run a GPU bench like Heaven with GPU-Z open to Sensors and select Power Consumption (W) to max.
You can check out your CPUs power usage with hwinfo64, under CPU power. You will need to run a CPU bench like Cinebench R15 to get the max power used.
Most 2080 tis use a lot more than 300 watts and use standard coolers.
My EVGA XC that is a 2 fan, 2 slot card uses 347 watts max and my FTW3 Ultra uses 387 watts max.
The same sized cooler are on 2070s.
What makes the 2080 ti a bit frustrating to own is that all are limited by there cooling solution. By contrasts my GTX 1080 tis were limited by their clocks.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
