CPU works perfectly in everything other than games
Solved by sickomode,
13 hours ago, Moonzy said:from the photo, you're more gpu limited than cpu
try turning the game graphics down more, or turn the resolution down
and make sure your laptop isnt overheating
I actually tried overclocking the gpu by 50 Mhz but it went wrong a while ago. Maybe that can be the problem if you say that i am GPU limited.
Thank you very much for the help!
Featured Topics
Shadow1789 ·
2
1
JewPacaBraZ ·
Posted in Troubleshooting1 -
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows3 -
7
Faiyaz111 ·
Posted in Graphics Cards0 -
BigChungus1009 ·
Posted in Troubleshooting7
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
