1.42 at idle? I'm going to assume it's at idle. If so, that's perfectly normal. Since it's high voltage and low current, which is perfectly fine.
It will drop down under load.
2 minutes ago, Ichoumaz said:
can i just set the voltage at 1.35 without touching the core clocks
Every chip has different capabilities. Only way to check if it can hold it with the under volt is to try. But again, if this is at idle it's perfectly fine.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883420
yeah, at idle, and my idle temps arent exactly cool from 54 to 61, so wouldnt it mean that it will heat up faster when its hit with a load?
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883434
Nope. Those temps are perfectly fine.
Nothing wrong with your cpu.
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883442
1.42V at idle is fine, since there's very little current actually going through the CPU.
What's your Vcore at full load though?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883448
Just now, Ichoumaz said:
guess i should get a proper cooler than
You don't have to lol. If temps are under 85c/90c under load then there's nothing to worry about.
Idle temps don't matter. Load temps do.
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883453
tbh, this aint for me exactly, just a friend that was worried about his temps and voltages, i already have mine OCd to 4.05 GHz at 1.375 volts, i think his VCore was at 1.36 last ime he showed me
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883462
i think they acceed the 90 degrees underload but i'm not sure, i'll do a quick test
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883466
Under normal load or something like prime 95?
But yes check if possible.
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883475
i'm talking 40 C in the shade, so around that temp in my room
That would explain it then lol..
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883482
31 minutes ago, Ichoumaz said:
can i just set the voltage at 1.35 without touching the core clocks or overclocking the cpu and just let it do its own boosting?
No. The CPU boost algorithm doesn't work with static voltage.
You've two options
  1. Let the CPU boost the way it wants. Apply a slight undervolt (-0.1V at the most) if you want to manage the temps a bit.
  2. Use a manual overclock if you to use a static voltage.
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883522
7 minutes ago, Ichoumaz said:
my bad, i have it at 4 Ghz not 4.05
-snip-
Ah. Only use hwinfo64 or ryzen master to monitor ryzen temps correctly. Others can't Monitor it correctly.
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883523
You've two options
ahh okay, makes sense
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883529
is the max temp of the ryzen chips 95 C?
Usually they start to throttle at 90/85c plus. But afaik 95c is safe.
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883566
though it was at the very end of the test
Well ambient temps certainly will affect that.
But if temps under your normal workload are fine then i wouldn't worry about stress test temps. It's a stress test after all. But yes those ambient temps are certainly affecting these results.
Build Log:
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883590
48 minutes ago, Ichoumaz said:
it seems to have acceded the 95C limit
have you tried testing this with your side panel open to see if it's an airflow issue? 95c is really high for a 3600 even on stock cooler at 40c ambient...
and this is 1 cinebench run, without GPU running
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883739
i havent, i'm sure the temps will go down a bit if i do, the case has 2 intake fans and one exhaust fan, and it seems to have good airflow but maybe the fans themselves arent that good, i'll give it a try and let you now
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883754
okay, i tried it without the side pannel, and it seems to be the same temp after just 1 cinebench run
https://linustechtips.com/topic/1229665-voltage-control/#findComment-13883827
