Full ATX Case with mac height of 42cm
Phse0
Hi everyone,
I am looking for a full atx case with a max height of 42,5cm.
Is there even something like that?
Regards,
Philipp
Hmm... What are the other dimensions requirements? Because you could just lay most casing on its side if it's only the height you're worried about
-sigh- feeling like I'm being too negative lately
Corsair Air 540, 680X?
I'm not exactly sure whether they're under 425mm but I think they're your best bet when it comes to ATX cases.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I want to place the pc under the desk. Otherwise it steals too much of my limited space. Laying on it side is not a real option, but thank for the idea :)
Remember to leave about 2 inch gap on all sides for the air to flow
