does any monitor work ?
dave2700
does any monitor work for a custom build or do you have to look at any specs?
any modern monitor will work with any modern system, because they'll almost all use displayport by this point. If you're going back in time a good few years, you'll have to make sure the monitor has the right ports to work with the graphics card. However, in the old days, most 144Hz monitors that had DVI and HDMI could only do high refresh rate over DVI so keep that in mind for the earliest gaming monitors.
Primary PC:
Any monitor will 'work'.
However if ur after any type of quality u need to know what to look for. Check pinned threads as they usually address common questions relating to the topic they are in.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
