Razer 15 2020 Battery Life
So after several days of testing and researching, I've pinpointed the issue (I think). This is for people who may come across this issue in the future.
Firstly, for whatever reason, my computer was wanting to use the Nvidia GPU while it was on battery and doing light tasks (document editing, Youtube, etc). Even after setting the global settings in the control panel to only use integrated graphics, it still did not work correctly. I found this out by using ThrottleStop's temperature monitoring software, which kept randomly giving me my GPU temps and then also giving me a 0 degrees reading, meaning it was trying to read the UHD graphics and was failing since apparently there is no sensor to give data. This constant state of switching between integrated and discrete graphics was pulling on my battery unnecessarily and was the apparent main cause of my poor battery life.
There was a Windows update to 2004 which I downloaded and installed. First thing I noticed was that now my global settings were being adhered too, and now my GPU reading remains steady at 0 doing normal everyday tasks. Somewhat perplexed, as I figured this wouldn't solve it and all of this was due to Razer's shitty battery/hardware, I ran some tests. I actually managed about 3.5 hours on battery, so of course while not stellar by any means, it is lightyears ahead of what I was getting before.
Within my first ten or fifteen minutes prior to the update, I'd usually see the battery around 85%. Now, within that timeframe I'm still around 96% so I'm glad to have this more or less rectified. A big thanks to those that tried to assist me in this matter, I'll @ you guys just so you can see what my solution was.
