Budgetest Mobo for Ryzen 5 3600XT?
12 minutes ago, spencerstephens said:
well different motherboards come with different feature sets as well as different VRM phases. the more quality the VRMs, the more smoother, cooler and better your components will run. with a higher priced motherboard, you get better VRM solutions, VRM cooling with heatsinks, multiple m.2 slots, better I/O, wifi, etc. the low price ones generally lack most/all of these.
14 minutes ago, spencerstephens said:I just want a basic mobo, compatible with the following potential part list, that won't give me problems or drop performance, and for the best price.
the b450 tomahawk is a relatively mid ranger board, it offers excellent VRMs, and can easily run your 3600XT, though im not sure why youre putting a nvme drive in a budget build. m.2 sata or regular sata should fit your budget and fulfil your needs.
15 minutes ago, spencerstephens said:Nvidia 1650s
Ryzen 5 3600XT
3200mhz DDR4 RAM 2x4gb
and an NVME M.2 SSD
i would get 16 gigs of RAM, as thats the recommended minimum for gaming and similar tasks.i dont get why youre getting a 3600XT, a 3600 or 3600X should do, youre just getting higher clocks there.
id suggest waiting for zen3 and ampere to release (new gen ryzen cpus and nvidia gpus). that way, you could probably get a better cpu for the same price of the 4th generation cpus, as well as either get a new 3000 series ampere gpu, or a used 2060 or 2060super for the same price
