Goodmorning,
I'm looking into building my first pc and deciding to go with the nzxt h710i case.
I was wondering if somebody was using this case with a push/pull config using a kraken z73/x73.
Is the mounting self explanatory or do i need i need to buy extra screws if i want push/pull?
Also i noticed the H710i case comes with a "Smart Device V2" , so the radiator will be sandwiched by 6x 120mm fans (the 3 included + the 3 radiator fans.
Their is 1 included 120mm (or 140mm fans i can't recall anymore) at the back (exhaust) and i would buy 2x 140mm fans for the top (mounted on the bracket) also for exhaust.
The 2x 140mm rgb pack i would buy comes with a hue+ controller, is that needed assuming the case comes with a "smart device V2".
Thanks for reviewing my question ;)
https://linustechtips.com/topic/1227224-nzxt-h710i-case/
Push/pull is only possible in the front, though can mount push or pull at the top.
"Front mounted 360mm AIO is set up with 6 matching fans for a push/pull setup."
https://pcpartpicker.com/b/Tcf9TW
You can see example builds at PCPartPicker
https://pcpartpicker.com/builds/by_part/Y3FKHx#h=164636,279283
https://linustechtips.com/topic/1227224-nzxt-h710i-case/#findComment-13863778
  Hide contents
Goodmorning,
Thanks for the info , didn't know i could look at builds this way.
I was definitely gonna put the radiator in front for push/pull, thought i mentioned that but i didnt.
I also found out that i dont need the added hue bridge with the nzxt fan pack , the smart device V2 command RPM and RGB colors for all fans attached.
The only thing i'm worried about it the amount of fans and controlling them , i mean like : radiator has 6 fans , top exhaust i'm installing 2 x 140mm fans and backside has 1 fan also , do i need to use cable fan splitters or somesort or does this case have me covered ?
https://linustechtips.com/topic/1227224-nzxt-h710i-case/#findComment-13866227
I believe you'll need at least one spliter for all the fans. Whether you use the spliter for the exhaust fans or the intake fans is up to you.
https://linustechtips.com/topic/1227224-nzxt-h710i-case/#findComment-13866905
