Volume Bar not showing??
Solved by Eschew,
Hey there. Did a quick search, seems like issues with the volume OSD not showing up are commonly caused by conflicting drivers or sound software. Try updating your drivers, or uninstalling any suspect third-party software? Some suggested solutions that may or may not solve your issue:
- Volume OSD is Missing on Windows 10 by Windows Report.
- Enable the Volume OSD in Windows 10 on Super User (Stack Exchange).
If the the links above don't solve your issue, try using "Volume OSD" as a keyword in your Google searches. It should pop up more relevant searches compared to "Volume Bar" or "Volume Control".
Apologies that I can't be of more help, I've no first-hand experience with volume OSD issues. Only hoping I could point you in the right direction.
