Is there a limit on how much power can be safely drawn through a single molex power cable? Most cables have up to 4 connectors daisy chained together, but this doesn't necessarily mean its safe to have any 4 molex powered components drawing from the single cable. I know normal hard drives/ssds only use 6-10 watts each, but I'm looking to power 6 65W components with as few cables as possible.
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
https://linustechtips.com/topic/122518-molex-cable-power-draw/
6 65 watt components? do you have a good sized power supply?
I'm looking for a good PSU in the 550-650W range based on what calculations I've done myself, but temporarily I will have this running off a Corsair AX1200 that I use for my test bench. Limited number of molex/sata power cables on psu's is actually why I'm asking. most modular psu's in the 550-650w range only have room for 3-5 molex cables.
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630079
what do you want to power?
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630083
6 GTX 750tis plugged into 6 of these:
The GTX 750tis have no extra 6pin connector and the riser is designed to take no power from the motherboard, so it takes what power it needs from the molex connector. The GPU has a TDP of 60W and you need to allow a bit more for vram etc, so 65w is a good estimate.
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630104
As far as I know molex is good only for 11A (https://en.wikipedia.org/wiki/Molex_connector). If you have one with 18 AWG wire then the wire can survive 16A but the pin might not cope with it. Seems like the molex connector can pass enough power for what you are wanting to do, assuming the motherboard can deliver the amps down the molex completely and not reserving a lot of the 12V amps PCI-E connectors.
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630132
Is that for mining? :D
Potatoes are good for your nostrils.
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630146
I know that it works for at least one GTX 750ti, because I have one running right now. My problem is a shortage of molex connectors, and I'm not sure one cable could handle 2 of them. Is there a way of finding the amperage and voltage of my GPU?
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630148
Close, but no. It's for Folding. Kinda like mining, except you are calculating molecular physics to help find cures to diseases rather than algorithms for money.
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630155
Here are the basic numbers.
A PCI-E card with no addition plugs that is 16x can use up to 75W TDP, electrically for short bursts it can pull more than that, to the tune of about 150W but its longer term (as in 1 second) can't exceed 75W.
A Molex can delvier 12x11 = 132W
A 18 AWG cable can deliver 16x12 = 192W
A 750ti consumes 60W long term as confirmed by reviews.
It sure looks like it just about fits to me.
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630767
Based on that it does look like I could power 2 cards with one cable, or at least wattage wise. Should I be concerned about the amperage? When components are daisy chained together does the amperage add together?
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/122518-molex-cable-power-draw/#findComment-1630933
