I don't feel a difference in fps
Johnny-Boi
soooo, my dad just got a gaming pc, and at first when i was messing around with some games on it, he accidentally left it at locked 60hz, after fixing this the fps went up to 75-95, i then had him put it down to high instead of ultra, and then after it went to 120fps i didn't feel a difference. am i just not focusing on the right things, or is it just me? can anyone help me figure this out? sorry if this is a stupid thing to ask.
@Johnny-Boi聽or DM me on discord
@King of Reeeeee Land#9814 聽
PC is a work in progress, open to any tips and suggestions with ways listed above聽馃槈
What is the Hz of the monitor?
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores聽- Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD聽&聽2x 1TB Seagate Drive OS: Win10
depends on your monitor's refresh rate, if it's 60hz, you wont see any smoother animations if your game is running above 60
you would feel like it's more responsive as there is less gap between input and display, but you would also experience tearing
but some people are also not able to tell the difference between 60hz and 120hz at first, it takes them awhile
edit: this video explains it better, i suppose
-sigh- feeling like I'm being too negative lately
Im the same. I dont notice a difference at all when above 60fps. I can definitively notice lower but I have monitors that are 144 and 300 but I can not tell a difference at all. Physical size and graphics quality matter more to me.
I am far from an expert in this so please correct me if I鈥檓 wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
I was the same way when I first started gaming at 120Hz, I didn鈥檛 notice a difference at all compared to 60Hz. After playing at 120Hz聽for a while, I left the monitor capped at 60Hz one time聽and noticed something was off pretty soon.聽You might just have to get used to higher refresh rates.聽
I don't have any monitor with a refresh rate higher than 60Hz but I did upgrade one to 75Hz but didn't notice any difference. However I do notice when the game runs below 60Hz on my PC but I'm totally fine playing at 30FPS on my PS4. Is there a reason behind it?
  • 2 months later...
Going from 30 to 60, or vice versa, is very noticeable for most people.聽
Once you get over 60 it becomes much less pronounced.聽
I find it difficult to tell any difference between 75 and 100 fps, or 120 and 160.
Perhaps, some people are very tuned in and can notice even the slightest drop - most don't.聽
60fps for lyfe crew #
I'm super sensitive to this shit聽 hence I'm only playing at 60fps聽 locked,聽 1 fps drop I get immediately crisis and want to reinstall windows... Oof.聽
(only slightly exaggerating)
The direction tells you... the direction.聽
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)聽
MSI Afterburner聽
OpenRGB
Lively Wallpaper聽
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity聽
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop聽
Superposition聽
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
You can really tell if there's one frame dropped?
Err, yep even before afterburner or gfe聽 overlay聽 shows it (there's聽 a delay)
-Scott Manley, 2021
Softwares used:
MSI Afterburner聽
OpenRGB
Lively Wallpaper聽
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity聽
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop聽
Superposition聽
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
That's pretty impressive actually, to be that attuned.
