troubleshooting PC won't start after using bios flash
Solved by Alkocicero,
1 minute ago, ItsNypz said:U said I need another gpu, but like I said I have another computer, can't I replace a specific part of my pc with the other pc in order to go on my pc and just use the backup of the bios? (I think i need to switch the gpu, right?)
if you have another pc then take out gpu and put it in the top slot on your motherboard and the vega card in the bottom slot and see if you can boot into windows, you then need to make sure the vega card is reporting hardware to windows, you can check this with gpuz.
if you can still see the card in windows attempt to flash the backup you made. be sure you select the right gpu when flashing as you dont want to flash the wrong card.
