I've been trying to overclock my i7 6800k and for some reason in Bios it says my CPU is overclocked at 4ghz but every time I open task manager and look at the CPU speed it tops out at 3.6GHz when running stress tests like prime95. The VCCIN voltage is set at 1.775 and the CPU core is 1.2
https://linustechtips.com/topic/1223508-i7-6800k-overclock-issue/
Intel disabled overclocking on Broadwell-E due to security issues, you could be facing this issue.
Personal Desktop":
Luna, the temporary Desktop:
Is there anyway around that or am I just out of luck with that. Is it just worth it to consider upgrading to another motherboard and CPU?
If it's worth or not depends on your need, if the CPU no longer suffices to what you do and you want more there certainly are good choices from either Intel or AMD, anything with 8 or more cores.
If you just want to overclock you might be able to do so if you install specific BIOS for your motherboard, it'll be something to search about.
Personal Desktop":
Using InSpectre to disable the spectre and meltdown updates and microcode changes may help with that, those side channel attacks are only theoretical anyhow, and haven't been explored upon, so I always disable those on my intel systems.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
MSI motherboard by any chance?
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
