I have a Asus TUF 570X mb.
Now I can only afford two CPUs. That come up as good ones.
A Ryzen 5 3600
Or
A Ryzen 7 2700x
What would fit better with my motherboard as I'm confused.
Usually the 2 series uses 460x mb etc and the 3 series handles 560x mb better.
But the r7 2700x uses more voltage. And is 10% cooler, 2 more core and 6 more threads. So wouldent this be better on a more wattage hungry motherboard?
I'm trying to get what I can only afford out of the two, but also make these last several years.
My...amd... FX........ Black versha 4.2ghz 8 core lasted me 8 years being about 10 years old in tech and I play warzone on high settings. So even 10 years later it plays the latest games. Thermal throttling is my problem though 😅🤪. But it runs okay.
So what do I do to be more future "proof" I'm thinking a good 7 years keeping this build for.
Also this is paired with 32gb Corsair 2x16 cl 16 ram.
A Geforce 1660 super 6gb GPU.
Thank you, you clever people!!
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/
Unless you exclusively do heavily multithreaded tasks where you'll notice a 10% difference in performance between the two CPUs, get the 3600.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/#findComment-13831632
More voltage?
We don't know what will be more "future proof" but. Both will be similar in most tasks. In tasks where it's just multi threaded and nothing else. The 2700x will beat the 3600 but in 90% of the cases they are similar.
Go for the 3600.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/#findComment-13831649
Being the latest among the both, Ryzen 5 3600 definitely ticks the box for being a more advanced processor. Based on Zen 2 architecture, it is a better processor in terms of faster single,dual and quad core speed. It also boosts a faster overclocked single,dual and quad core speed. It is a lot cheaper when compared with Ryzen 7 2700, hence gives us better value in terms of price. It also has a very low TDP as compared to 2700 and hence can be taken as a much energy efficient model. So, if you are choosing among these two then 3600 is the best option but but Zen 3 processors are gonna be here soon so you always have a option of waiting a bit more and buying the best available product.
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/#findComment-13831682
If you're basing all of this on Userbenchmark (going by the "single, dual and quad core" metrics you mentioned), I'd advise you instead look up reviews and benchmarks run by actual reputable reviewers.
Not that it's not true that the 3600 is faster in all workloads except those that can fully leverage all 16 threads of the 2700X, but in plenty of cases Usermememark and other similar websites will provide very misleading numbers, especially when you start comparing an Intel and an AMD CPU head to head.
Gamers Nexus, Hardware Unboxed, Guru3D, Tom's Hardware, Anandtech and many others are reliable sources for benchmarks/performance measurements.
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/#findComment-13831811
Hey, thanks for the suggestions. I will surely analyse from the reviews of the experts mentioned by you. :)
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/#findComment-13831821
Never get anything from user benchmark.
It's always fake ;).
Build Log:
https://linustechtips.com/topic/1223299-need-expert-help-ryzen/#findComment-13831832
