2 minutes ago, JustAGamer325 said:
Like 3 days or sth. Why?
ur fine then, just enable pbo like others said and u aren't missing anything and 3600 on the ram
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13816994
3 hours ago, 5x5 said:
efficient at controlling Zen than end users.
*most
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13817440
1 minute ago, Letgomyleghoe said:
*most
Got my 3600 at 4.3ghz 1.35v (ik not ideal but it’s gonna go to my closet pretty soon) but my cpu wasn’t boosting over 4.2.
-ran cinenench stable
AMD blackout rig
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13817447
5 hours ago, 5x5 said:
He hasn't degraded anything for a few days. Degradation occurs over the course of weeks or months even. No need to panick him even more
So... update: I turned off my PC for about 2 hours to go do some other stuff. When I came back and turned it on, the same framedrops occured. Restarting the PC seemed to fix the issue though. I also turned on a-xmp profile 1 since msi has two profiles and 1 is allegedly more stable.
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13817891
Did you revert everything to stock as instructed? Aka, clear CMOS?
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13818193
Yup, returned everything as it was when i got the system running for the first time. though I left PBO on. Every time I turn on the PC I experience framedrops and I have to restart to make them go away.
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13819063
What are your thermals and clockspeeds when frame drops occur? Use HWiNFO to track them
https://linustechtips.com/topic/1221522-cpu-problem/page/2/#findComment-13820116
