Can I run over 120fps on a 144hz monitor
Chriszaw21
Can you guys please help me. Idk if I should run over 120 FPS on a 144hz monitor, I don’t want to damage the monitor in anyway.
the monitor is a 144hz 3.1ms
Go to display settings and set it at 120fps. You won’t hurt the monitor
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
If the monitor is meant or advertised for 144hz then you shouldn't be able to damage it in any way by running it at 144hz.
you can whatever fps to the monitor, the monitor doesn't care. It will just refresh 144 times a second, no matter the fps you're using (unless it has GSync/Freesync, in which case it will match the Hz to the fps).
