I need to know if my psu will work fine with rx 560
Solved by mariushm,
Like the others said, a RX 560 consumes under 100 watts.
x3440 and motherboard and ram will be less than 100 watts on average.
That psu says it has 3 12v rails, each with 18-19A (~ 220w) and normally you don't add them up together, an honest psu would have around 45A in total on those 3 rails, or around 550w .... but I strongly suspect the psu is lying about its capabilities and it can probably do around 350-400w in total on 12v.
With the new video card, you probably won't go over 200-250w so everything should be fine.... but you should seriously consider replacing the psu with one from a brand that doesn't have fake labels or lie on labels.
