Just finished putting together my PC, when I turn it on, the RGB for the Motherboard and RAM light up, the power supply fan spins up for about 4-6 seconds and then stops, I'm getting no display to my monitor, and no beeping(someone asked about my motherboard speaker, I said I didn't know anything about it).
I'll post the parts I'm using, and they are a bit strange, our company ordered the wrong parts or too much of something and we were just told to take what we want.
https://pcpartpicker.com/user/Tacos16x20/saved/#view=ptFQD3
I'm using Corsair Vengeance Led 4 x 8gb 3200MHz for RAM
https://linustechtips.com/topic/1215796-please-help-me/
Just connect the drive you want as boot, first... then add the rest later.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768701
1 minute ago, Tacos16x20 said:
But shouldn't any of the fans be spinning? Even the CPU fan? Because not a single fan is spinning
Can the 'board get into the BIOS?
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768710
It usually comes in the box as a separate little item
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768721
2 minutes ago, Tacos16x20 said:
When i turn it on and connect display, i dont get anything, only black screens
Did you test the 'board, on the box, before you built into the case?
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768730
These aren't as common as they used to be, these days... esp. with the rise in populairty of code displays.
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768734
Just now, Tacos16x20 said:
I probably should have done that, i got a little ahead of myself watching a build guide
Oh dear... strip the build & test the core spec., first.
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768740
As "The Master" always says - "do as I SAY, not as I DO."
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768743
2 minutes ago, TekSupport said:
First I would read this Post, and try the steps it recommends.
Dat flowchart, though...  😲
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768749
Not sure if this is common knowledge or not, but do i need to have a hard drive plugged in when i take the mobo out and start it up?
Not to get to the BIOS; no...
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768794
Alright, i have the motherboard out, sitting on the mobo box, the cpu 8 pin cable plugged in, and the 24 pin plugged in, monitor plugged into the motherboard as well, using display port, is there anything else i need to do before i turn the power supply on?
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768850
Graphics card - 3600 has no iGPU.
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768857
Yup... then get ready to 'mash' Delete - on keyboard - to get to BIOS
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768870
Turned the Power supply on, the rgb on the mobo lights up, the ram no longer lights up, none of the fans are spinning up (ie. cpu cooler, gpu, and psu), no display whatsoever either
No noise from the motherboard, no little red dot or anything anywhere either
Turned the power supply off after about 45 seconds because it didnt seem right
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768886
Is the CPU cooler fan connected?
Reseat two matched RAM sticks in slots 2 & 4 - away from the CPU.
Does the 1060 have it's power?
WHY NOT...?!
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768903
Fan is plugged into CPU_FAN
Changed the RAM slots so now its 2 and 4
And yes the GPU has its 6 pin plugged into it
https://linustechtips.com/topic/1215796-please-help-me/#findComment-13768927
