Doubt regarding making connections
Solved by Guest,
Dude... You can go from the +12V on the 24-pin to a +12V to a PCIe connector. It doesn't matter.
As long as you don't mix the voltages.
And make sure you have a multi-meter before you get started.
FancyPants101 ·
Posted in Troubleshooting0 -
BoBo6107 ·
R_public ·
Posted in Networking13 -
apoyusiken ·
Posted in PC Gaming1 -
4
MattJames595 ·
Jimkirk363 ·
Posted in Windows4 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory7
