Idle temps GPU
Go to solution Solved by Statik,
1 minute ago, Radium_Angel said:
I know, right? If I watch my GPU at idle, the fan isn't spinning, this is just airflow from the case moving past. The fan only spins when needed apparently.
Ok that's easy enough. Your particular model probably has a 0RPM mode. So under a certain temp (more often than not, 60C), your fans won't spin at all to keep your GPU virtually silent. So once you hit load I'd assume you hit 60C, and your fans just keep it in that ballpark. I assume if you had a curve set up at idle you'd be a lot cooler. That makes sense
So I have an asus rtx 2070 super 8gb, and it's quite cold right now, well for me anyway it's around 17 degrees, and the card is idling at around 48 and 46 degrees, I am wondering if this is normal and not  a cause for concern? I only got this system  months ago so this is my first high end system and just getting used to the things
https://linustechtips.com/topic/1214965-idle-temps-gpu/
Make sure you haven't selected "Prefer Maximum Performance" as the power setting in the Nvidia Control Panel. Otherwise, considering the fans on your card won't turn on up until around 50-60C by default, it's kind of to be expected to have a little higher idle temps.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1214965-idle-temps-gpu/#findComment-13762623
4 minutes ago, Radium_Angel said:
That's fine. MY GTX 1060 idles at 55 deg, and even under full load doesn't go above 60
how can going from 0% - 100% load increase your temp by 5C? That blows my mind?
EDIT: Also OP what are your fans spinning at? My Asus 2080S idles around ~25C (usually a cooler ambient as well), and load never has broken 65C.
Granted, even if your idle is in the 40s, that doesn't matter too much. What really matters is your load temps.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1214965-idle-temps-gpu/#findComment-13762630
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1214965-idle-temps-gpu/#findComment-13762650
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1214965-idle-temps-gpu/#findComment-13762665
It's perfectly normal
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1214965-idle-temps-gpu/#findComment-13762672
Yeah haha, my fans only spins when it hits 55C, thank you all for your help 😛 right now it's idling at 35c, but after gaming it cools down and remains at around 45c which i assume is perfectly normal, so thanks for your help haha
https://linustechtips.com/topic/1214965-idle-temps-gpu/#findComment-13762951
