im scared that my first pc build wont work because bunch of problems others encounter shows up on my youtube recommendation and it scares me that WHAT IF ifleep the whole thing up but the mobo doesnt support ryzen 3 3200g because the mobo isnt updated.. should i buy MOBO WITH FLASH BIOS or just buy cheap mobo and buy an old gen cpu which will cost more lol. i live in a country where pc parts were 20% higher of the price compare to us thanks in advance
https://linustechtips.com/topic/1214165-newbie-problem/
what motherboard?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756040
What components are you looking at?
Some 400 series boards (B450 and X470, though going with X470 today makes little to no sense) come with a recent enough BIOS version to run Ryzen 3000 out of the box.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756043
Most b450 boards right now are manufactured and comes out of the box with zen 2 support even if it doesn't list it
If you got an old b450 board just ask a computer store or the vendor if they can update it for you
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756060
ohhhh thank you so much now i can sleep better at night! THANKS!!!!!!!!
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756083
Just now, Gushiees said:
ready do u know some?
Tomhawk max
Mortar max
Gaming plus max
Build Log:
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756088
thank you so much really help me as a newb
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756089
13 minutes ago, boggy77 said:
just ask the vendor before buying whether it suports 3000 out of the box (it should have a "3000 ready" sticker on the box).
otherwise, all b450 max boards from msi support 3000 series out of the box.
THANKYOU SO MUCH now im not afraid to pick a mobo lmao
https://linustechtips.com/topic/1214165-newbie-problem/#findComment-13756097
