Budget (including currency): around 700-800 EUROS
Country:  Spain
Games, programs or workloads that it will be used for:  Heavy programming and AAA Games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Hi, so I want to build my first PC with a focus on High framerates and relatively good graphics. Are these parts good enough / compatible?:
CPU: AMD Ryzen 5 3600                                          180$
Motherboard: MSI B450M Pro-M2    mATX               70$
RAM: Corsair Vengeance LPX  2x8GB 3000MHz     78$
PS: Corsair CX550 semi modular                              80$
SSD: Sabrent Rocket NVMe 512GB                         90$
Case: cougar mX330-G                                             50$
GPU: Msi GeForce GTX 1050 Ti 4GB                        150$
Total:        698$
https://linustechtips.com/topic/1213675-my-first-pc-build/
since you're spending in euros that build only being 700$ means you could probably upgrade to a 1660S instead of a 1050ti
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1213675-my-first-pc-build/#findComment-13752267
No there is a heavy import tax in europe 1 euro = 1 dollar
CPU: Ryzen 5 3600
GPU: Gigabyte gtx 1660 Super oc 6g
Mobo:MSI b450 tomahawk max
RAM: 32gb ddr4 lpx vengeance 3200mhz
Storage: WD sn550 1tb, Baracuda 2TB HDD (*In use), Hitachi 2tb HDD, WD 0.5tb HDD (both HDD knackered)
PSU: cxm 450
Case: Corsair Carbide Series
https://linustechtips.com/topic/1213675-my-first-pc-build/#findComment-13752268
you can do much much better with that budget. the msi pro-m2 is a bad motehrboard that can't support a 3600. the 1050ti is a low end gpu, not suitable for high fps gaming.
https://linustechtips.com/topic/1213675-my-first-pc-build/#findComment-13752269
you could even switch out the 3600 and get a 3300x and use the extra money on a 5700xt, or a better motherboard
https://linustechtips.com/topic/1213675-my-first-pc-build/#findComment-13752323
24 minutes ago, Tarbot said:
What is your "Heavy Programming"?  Are you coding or is it AutoCAD / Microstation or custom company software?  Do you need to do any BIM Modeling, GIS work, Load Calculations?
I'm learning to program with Unreal Engine 4
https://linustechtips.com/topic/1213675-my-first-pc-build/#findComment-13752344
