I need advice, I have a dell prebuilt office pc. It has always been my dream to make a gaming rig, and I need advice on a couple of things. I want to change the pc a little bit, so I want to add a dedicated gpu. 1660S to be exact (I saw your video on gpu's to buy in early 2020). I already checked the dimensions and it will fit in the case. I only need help with this: my motherboard is kind of old, considering that it comes in an older dell pc. It does have a x16 slot, so does that mean that I can put it there? Also, Should I change the power supply? it is a 250W psu. Anyone who I've spoken to told me that I need to check the compatibility of my motherboard with my card. But, as long as I see it, the only thing it needs to have is an x16 pci slot. I just hope you can help me and tell me what should I get, should I change the motherboard? Should I change the psu?
Thanks in advance
Rian
https://linustechtips.com/topic/1213353-i-need-help-with-my-gpu/
Don't change the PSU or mobo
They are most likely proprietary
As for the GPU , a 1650 would probably be the best thing in this case as it doesn't need a pcie connector
Who in the hell told you that
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
Do you know which CPU, how much RAM, the name of your motherboard and PSU?
Click on start, type System Information and copy paste us system summary this will give us everything except for the power supply.
If you do go changing the PSU you might need an adapter cable. Take a picture inside the PC and show us.
CPU: AMD Ryzen 9 5900X 12; GPU: GeForce RTX 3080 Gigabyte Vision OC V2 10GB; PSU: EVGA 750W 80+ Gold Certified; RAM: 4x32GB (w/RGB xd); SSD: 1xM.2 Samsung 980 Pro 1TB, 1xM.2 Samsung 970 Pro 1TB, 1xWD 6TB HDD; OS: 10; Monitor: 1xAorus IPS 27" (2560x1400) 1xBenq IPS 32" 4kKeyboard: Corsair K95; Mouse: Logitech G Pro X Superlight w/ Steelseries QcK mousepad.
Laptop - HP Omen 15" w/5800U, GPU 3070, 1TB M.2 WD Black, 2TB M.2 Samsung 980 Pro, 64GB RAM.
some prebuilds dont support all gpus
Any Help is appricated! Please correct me if I´m wrong!
Sorry for grammer/spelling mistakes, but english is not my native language
What is your PC's exact model? Knowing more about your CPU, motherboard and PSU would be helpful.
With some prebuilts, it is best to keep the motherboard, RAM, CPU and storage, but buy a new case and power supply for standard ATX compatibility (e.g., prebuilt PSUs often lack PCI-E power cables which many graphics cards require).
No. Lol
Some prebuilts have proprietory firmware that doesn't allow a dgpu lmao
Build Log:
That PSU's certainly need help, depending the prebuilt you may not be able to replace it completely however which means you need to run two PSUs together.
Desktop benching:
With pre-built mobo you can have to do some cutting and soldering to fit them in a new case ... I had to do so to fit the power button and all the front IO (well i stopped at the hdd light honestly) with a dell 7010 motherboard, but the psu connectors were standard.
2 minutes ago, TofuHaroto said:
No. Lol
I had a lenovo with an i7 2600 that supported only nvidia gpu and old amd gpu from the r9 era and didn't work at all with my rx470 ... I had to change my motherboard for a dell 7010 and that worked perfectly fine ... so no not all prebuilt can support all gpu.  some have a limited set of supported gpu.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
Hm
Weird
Build Log:
Just now, TofuHaroto said:
Hm
Weird
indeed and it made me freak out at first ... i tried it in my pc and my gf's pc but it didn't work in both cause we had the same lenovo base ... I feared that I was ripped off and got some old mining card with mining bios ... I contacted the seller and he found out why it wasn't working ... turned out that lenovo had a whitelist of gpu in their chipset and recent amd cards were not there even if I had the latest bios version.
I9 10850K
MSI Z490 Tomahawk
