GIGABYTE Gaming rx5700XT OC Water Cooling
Solved by Lipe123,
35 minutes ago, -rascal- said:
I've seen one (or a couple) custom waterblocks for the Gigabyte 5700 XT cards...hold on..
Does the Gaming 5700 XT use a reference PCB..?...might need to check.
I know the AORUS 5700 XT is a custom PCB, though.
I contacted that company and they said it will work on the Gigabyte gaming OC card.
Been meaning to get one myself but I'm waiting for the actual gfx card prices to go down.
