Budget (including currency): 800 CAD (591.13 USD)
Country: Canada
Games, programs or workloads that it will be used for: Rainbow 6 Siege, GTA V, Heroes and Generals, GMOD
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Planning on building this in late July/Early August
Thank you!
https://linustechtips.com/topic/1212911-first-build/
Welcome to the forum!
Country: Canada
Thank you!
I'd really look at the used market, or at the very least get something like this:
But buy a used GPU, something like an RX 580 8GB for $150 or less would be good. As for CPU options look for the R3 3300x when you actually go to buy parts, it would be a better gaming CPU.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1212911-first-build/#findComment-13746548
20 minutes ago, Charlie221 said:
Well since you plan on using this build mainly for gaming you could get a ryzen 3 as for that budget it frees up some extra money for something else
CPU: Ryzen 5 3600
GPU: Gigabyte gtx 1660 Super oc 6g
Mobo:MSI b450 tomahawk max
RAM: 32gb ddr4 lpx vengeance 3200mhz
Storage: WD sn550 1tb, Baracuda 2TB HDD (*In use), Hitachi 2tb HDD, WD 0.5tb HDD (both HDD knackered)
PSU: cxm 450
Case: Corsair Carbide Series
https://linustechtips.com/topic/1212911-first-build/#findComment-13746568
3 minutes ago, KGGaming said:
You could get a ryzen 3 3300x for like $179 cad
CPU: Ryzen 5 3600
PSU: cxm 450
https://linustechtips.com/topic/1212911-first-build/#findComment-13746583
Hello again,
Thank you very much for this... Do you know of any websites that sell used RX 580 8GB, or, would I be able to add this component after I have built the computer?
Also, Is the R3 3300x better than the R5 1600?
Thanks again!
https://linustechtips.com/topic/1212911-first-build/#findComment-13747061
15 minutes ago, Charlie221 said:
Hello again,
Thanks again!
You should be able to find an rx580 on Amazon or eBay. A gpu is not a component that you can add afterword because neither of the cpu doesn’t have an integrated gpu. The ryzen 5 1600 is better than the ryzen 3 3300X. If you can find it for less or a similar price to the ryzen 3 3300X then it’s worth it otherwise get the ryzen 3.
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1212911-first-build/#findComment-13747120
1 hour ago, Charlie221 said:
Hello again,
Thanks again!
Hello again!
Would this build work?
PCPartPicker Part List: https://ca.pcpartpicker.com/list/NQb4Wb
CPU: AMD Ryzen 5 1600 (12nm) 3.2 GHz 6-Core Processor  ($193.69 @ Amazon Canada)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($118.05 @ Vuugo)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory
Storage: ADATA SU655 480 GB 2.5" Solid State Drive  ($69.98 @ Amazon Canada)
Video Card: PowerColor Radeon RX 580 8 GB Video Card  ($237.11 @ Amazon Canada)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($64.50 @ Vuugo)
Power Supply: SeaSonic S12III 500 W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Newegg Canada)
Total: $763.32
Generated by PCPartPicker 2020-06-22 17:37 EDT-0400
https://linustechtips.com/topic/1212911-first-build/#findComment-13747327
Howdy everyone, Charlie back at it again...
Here is my current build:
CPU: AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($129.99 @ Newegg Canada)
Total: $462.51
Generated by PCPartPicker 2020-06-22 18:32 EDT-0400
Would I be able to upgrade my CPU and add on a Video card later on?
https://linustechtips.com/topic/1212911-first-build/#findComment-13747436
Ebay, or check you local market on Kijiji or the equivalent classifieds.
For gaming the 3300x would be better yes.
Yes the 2200G has integrated graphics, so you could upgrade the CPU and get a GPU later on. Although for $8 more get the 3200G.
https://ca.pcpartpicker.com/product/J8drxr/amd-ryzen-3-3200g-36-ghz-quad-core-processor-yd3200c5fhbox
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1212911-first-build/#findComment-13747661
Hello again
I think I have reached my final build, if you don't mind, may you give some feedback?
PCPartPicker Part List: https://ca.pcpartpicker.com/list/8KpxMc
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  ($79.40)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($74.75 @ Vuugo)
Wireless Network Adapter: Asus PCE-AC55BT B1 PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($46.75 @ Vuugo)
Total: $663.41
Generated by PCPartPicker 2020-06-22 20:42 EDT-0400
Thank you so much for helping out, I really appreciate it.
https://linustechtips.com/topic/1212911-first-build/#findComment-13747681
3 minutes ago, Charlie221 said:
Hello again
Total: $663.41
Looks good but if you can change the motherboard and get the 3200G.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1212911-first-build/#findComment-13747693
