Front/Rear Panel Headphone Jacks Not Working
johnsoner13
I recently got a pair of HD58X jubilee headphones and usually I have my headphones plugged into my blue yeti. But I wanted to see how they sounded directly from my motherboard. When I plugged them into my PC's headphone jacks (tried this with my cloud IIs as well) I just got some kind of high pitched noise/feedback, from the rear panel and front panel jacks. No other sound comes through, when I go into Windows and select something else as the playback device, the sound is still there. When booting up my PC, the sound isn’t present just up until about Windows is loaded and I have to enter my password.
They both worked fine recently, as I just got my blue yeti only a few weeks ago and had to have my headphones plugged into the rear panel jack which worked fine. But for some reason neither of the jacks are working anymore. Any ideas? I downloaded/updated realtek drivers but to no avail.
I think it’s some kind of interference but nothing has really changed since the jacks used to work.
Specs:
b450 tomahawk max
ryzen 5 2600
EVGA 650w supernova g2
NZXT S340
RX 5700 dd ultra
Specs:
b450 tomahawk max
ryzen 5 2600
NZXT S340
RX 5700 dd ultra
This happens for many people. I can't see what is happening but the dac could have fried or something. Not sure about this
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
try contacting msi customer support if you haven't already
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
