Vcore voltage too low?
Go to solution Solved by Guest,
Your Cpu looks pretty close to where it should be actually.
The first screen shot with 4ghz the voltage is a lie. Under a load it would be greatly increased to what they had set, around 1.4v respectively for 4000mhz. Which is accurate for that kind of manual overclock.
Your Cpu has a base clock of 3.2ghz. The Max single core XFR boost is 4.1ghz.
So your all core clocks between 3500 and 3600mhz are ok because they are boosted frequencies.
The 2700X model only boosts 3.8-3.9ghz stock. So everything looks ok from my seat.
Run the LLC higher to help prevent the Cpu from hanging. If that works, stick with it. V-droop and V-drop are real things. FX-9590 suffered from it very badly as an example from the past.
Hi guys! I would like to know if the CPU Vcore voltage is ok. I think it might be low because sometimes the computer randomly crashes, CPU goes out (CPU EZ debug led turns on) with monitor, keyboard and mouse signal but fans and hdds keep going. I was playing with overclocking to 3,45 GHz to 3,5 GHz and the same thing happens. I suspect my PSU's 8 pin connector isn't supplying enough voltage.spacer.png
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/
Maybe that;s just too little core voltage for this clock speed. Raise it.
It shouldnt have anything to do with the PSU as long as it's within ATX spec (which allows 10% variation for 12V for example, which is what the 8pin carries)
Desktop benching:
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722444
the thing is that those are default settings. I can see Vcore voltage reading around 1,35 V in the BIOS but closer to 1 V on windows
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722458
It may, however, have to do with your motherboard's VRM. What motherboard do you have?
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722462
By default the CPU downclocks according to use. As it does, the Vcore will reduce accordingly.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722466
That's not likely. I have bought this motherboard brand new and the same exact thing happened with the old Asrock B450 board. Is less frequent with this one tho. It's the MSI B450 Tomahawk
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722469
I didn't know that but I've been having this strange problem for a while now and haven't been able to find the cause. I'm planning to buy another PSU and RAM, eventhought RAM passed memtest86 twice but I have no idea what else to do apart from replacing 1 component at a time.
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722473
Then it's vdroop, add some LLC to compensate. Need LLC if you dont run auto voltage
Desktop benching:
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722493
5 minutes ago, joser1813 said:
Hi, I've just ran CPU Z stress test and Vcore voltage stays low
What frequency is that? The score seems low to me. Looks like you are underclocked.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722499
It's well over 3,2 GHz base clock. It's worth mentioning that I only have 1 stick of ram and that could be hurting the score in this case
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722516
3.2Ghz is low. From what I am seeing the all core boost should be something like 3.4Ghz.
https://www.techpowerup.com/review/amd-ryzen-7-2700/16.html
That'll be part of it.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722527
2 minutes ago, joser1813 said:
Shouldn't that be working fine on default settings?
didnt you say you played with overclocking?
Otherwise you could
1. clear CMOS (.e. wipes BIOS settings)
2. update BIOS
3. dont use newest Windows versions (i.e. 2004)
Desktop benching:
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722572
Otherwise you could
2. update BIOS
Yea but the issue have been present since I got the CPU. I've just started playing with some settings but the OC profile is not active at the moment. I can recreate the crash when I overclock with Ryzen master which has 1 V by default in the profile, that causes the CPU to go out. I think the issue is related to low voltage on default setting. However, I don't know why the voltage is low. BIOS is up to date. Chipset drivers are up to date. The crashes don't happen very often so I can use the PC all day long, except when it crashes every once in a while and that anoys me a lot.
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722597
Find the Cpu LLC setting and take it off of auto. Set it to the maximum setting and test.
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722611
See attached images. I've just manually adjusted the Vcore voltage to 1,25 but it stays closer to 1,05 on default settings. LLC in mode 8 on the BIOS. Looks like my CPU or the drivers aren't working properly. As far as I know, the CPU should be doing fine on default settings.
I don't understand which voltage they are talking about on this image. What am I missing?
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722735
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722882
I hope this works, I shouldn't need to replace any hardware if it does and that'd be fantastic. I will investigate more on that topic. Thanks a lot
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722902
I hope it works as well. Cause if it does, You'll lower the LLC down one click and test some more. :)
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722921
yeah definitely dont go max LLC, that stomps on voltage regulation like me on cockroaches
Desktop benching:
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722940
The board on auto is probably set to second highest.... At least my Asus boards are.
It won't hurt anything. It's a stock 65w part. It's hardly loading the VRMs.
Good looking out though!
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13722946
A quick question. I just watched GamersNexus video on LLC. Vdrop is a safety measure as far as I'm understading. Could Vdrop be causing the random crashes when the system is on completely default settings except for the memory (Auto everything)?
As I said, they happen, maybe once every 20 days in average with the tomahawk board. The crashes were more frequent on the Asrock B450 HDV R4.0.
Edit: If I go for 3,45 GHz manually with 1 V, I can recreate what happens randomly
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13723003
Well the Load Line Calibration is exactly for the v-droop remedy. Something you can play with. You don't have to use max, you could try a lower setting like lvl 2 maybe and see if the issue occurs more often.... It's flexible like that.
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13723019
Hi! I have an update on the situation. The problem has persisted, I think I've identified it as low voltage on the CPU (I don't know the cause yet). Tt might still be Vdroop but it doesn't go away even after playing with LLC. I've just experienced an slow down on my cursor which normally happens when the system is about to crash. This is time it didn't crash and Hwinfo registered a very low cpu voltage around 0,54 V. Reading about LLC on MSI boards, it appears the mode 1 is the highest, instead of mode 8. I'm trying mode 3 this time.
https://linustechtips.com/topic/1209914-vcore-voltage-too-low/#findComment-13740640
