2 minutes ago, Hendricks3 said:
cannot keep my 3600 below 50 c while gaming.
Really good temps
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1209824-r5-3600-cooling/#findComment-13721697
Just now, Hendricks3 said:
care to explain i dont follow?
Your temps are more than fine
Build Log:
https://linustechtips.com/topic/1209824-r5-3600-cooling/#findComment-13721706
Just now, Darpyface said:
As long as your CPU isn't going higher than 85 degress C, you're fine.
More like 90 but yes ;)
Build Log:
https://linustechtips.com/topic/1209824-r5-3600-cooling/#findComment-13721708
10 minutes ago, Hendricks3 said:
really? cuz im not comfortable with my cpu at 66+ c while gaming even tho its always @ 4.2ghz
Literally above average temps
Anything over 90c is dangerous
Build Log:
https://linustechtips.com/topic/1209824-r5-3600-cooling/#findComment-13721751
thanks bros
Your welcome
Build Log:
https://linustechtips.com/topic/1209824-r5-3600-cooling/#findComment-13721762
