Post Your Cable Management?
ciprian97pop
Surprised those cards aren't dying in there.
Why would they be dying?
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
Open air coolers and the lack of positive pressure. I can't keep my crappy 980's cool even with all my fans in the 540. Gotta switch out to blower style or run at 100% all the time.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
The most they hit on the top card on stock fan curve is 66c
Now if I crank them with a little cooler ambient they run at about 55-60 depending how cool I keep my room
Well here's my main rig. :P
23563007239_02ae6e2563_h.jpg2015-12-23_01-57-08 by Travis McClelland, on Flickr
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
My cable management isn't too bad.
post-246650-0-76247100-1450914366_thumb.
Its behind the motherboard where there is zero cable managment.
That is definitely pretty good for what you have. :P
Main rig on profile
VAULT - File Server
you need more PC in that case
Looking for a job
Mine is pretty good, the case makes it easy though:
150958.d66c140bb773efa0fe7cf69966938972.
This is the ultra budget build I did for my nephew's birthday, not bad cable management, if it was mine I would have blacked out all the cables with something, I still might when I can get around to it (I have to install some office software soon anyway):
154876.1312865589670afda7ea6fa4617ce12c.
CPU - Ryzen 7 5800x3D |  GPU - RTX 3080 TUF OC | Motherboard - ASUS TUF X570 | RAM - Patriot Viper Blackout 32GB 3200MHz | Case - InWin 805 | Boot Drive - Corsair MP600 PCIe 4.0  Storage - 2 x 1TB SSD's & 1 500GB SSD | PSU - Seasonic Focus Gold 1000w | Display - ASUS TUF VG27WQ Curved 1440P 165Hz | Cooling - ASUS TUF LC240 AIO + 5 aRGB Fans
fucking hell man that is some nutty cable management bro. puts my rig to shame :D and i would consider my cable management ok-goodish
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
Hehe thanks man :) The NZXT cases are awesome for neat builds.
the case can only help to a certain point mate.. after that it is down to the builder and that cable management is probably one of the best i have seen ever. no joke
Thanks buddy :) I wanna get some cable combs for the PCIe cables.....In fact I think i have one somewhere.
that would look awesome..
Yeah It should compliment it well. I'm getting a Kraken x61 cooler and some new fans for Xmas so I'll put the comb(s) on when I fit those. Probably boxing day as I don't think it would go down too well if I took the table up with my PC during Xmas dinner :P
Yeah It should compliment it well. I'm getting a Kraken x61 cooler and some new fans for Xmas so I'll put the comb(s) on when I fit those. Probably boxing day as I don't think it would go down too well if I took the table up with my PC during Xmas dinner :Py
yeah :D i think with the aio it would look better than the air cooler thats in the photo :) would you show me pics when you do install it and stuff?
Oh definitely! I'll be updating my pcpartpicker page for sure and posting it here.
great :)
Yes it is in a drawer. These zip ties actually came with the power supply so I had no part in that. Its just a HTPC so heat shouldn't be too much of a problem as long as I don't close it.
For a first build, I think I did pretty good.
The only thing that annoys me is the Corsair Link USB cable.
post-188308-0-07804900-1451040934_thumb.
InsertGoodNameHere: Now with working power supply!
Why don't you disconnect the Corsair Link USB when you're not using it, I mean its only use really is to change the colour of the light on the cpu heat sink.
Not the cleanest of systems but it has lovely airflow and I have great CPU temps under load with a i7 4790k overclocked to 4.8Ghz (1.25vcore)
Here is mine.
Let me know what you think :D
post-130253-0-92798800-1451149075_thumb.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
I've been considering that. Might do it later.
Are the newer dongles shorter then the last series?
I'm guessing that's a joke. Assuming otherwise, I'm not sure. Find out for yourself ( ͡~ ͜ʖ ͡°)
