Here's mine, it's pretty good, though the side panel is a bit of a bitch to get on, but there's no bulge when you finally manage to get it on.
Front of house: (the cables you can see in the bottom right are from my keyboard and speakers and stuff, not the rig itself)
And the back room:
CPU: i7-8700K
Motherboard: ASUS Prime Z370-A
Memory: 32GB TridentZ RGB
GPU: Gigabyte GTX970 G1 Gaming
Storage: 256GB Samsung 850 Pro, 4TB WD Black, 1TB Seagate somethingorother
Camera sucks terribly, but here goes...
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
All those ssds :D
Main Rig
Plex Server WIP
My new freeNAS server more or less all set up....I'd really love to tidy up the sata power/data cables, but I'm really not sure how sure how. My thought was to buy two single molex to 4 Sata adapter chains (or more, but 4 is the most I've seen) but that will only help once I've added more drives. The second option is to buy more flexible data cables...but I'm not really sure what would work...or if it would even be better. Then there's the fact that the server is going to be sitting in some closet (with airflow, don't panic), so spending money to make the cable management better is just stupid.
/coiling up the sata cables would also help a decent bit....
//I'm considering picking up one of these to tidy up the sata power cables: http://www.newegg.com/Product/Product.aspx?Item=N82E16812162011,although I think the data cables are the bigger issue.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
fill all the hard drive slots! Lol when i think nas i think little box. Looks nice.
Well, I'm probably going to throw in an old 750gb drive I've got lying around (at some point) to do nightly/weekly system backups. But eventually I plan on throwing in another three WD Reds (not for a few years though).
PSU Tier List | CoC
Not the world's most advanced cablemanagement guy here.
• CASE: » CoolerMaster C700M » •  MB:     » ASUS ROG RAMPAGE VI EXTREME »»» LGA 2066 •  CPU:    » Intel i9-9980XE Extreme Edition - 18-Core @ 3.00Ghz •  GPU:   » Inno3D GeForce RTX 3090 - 24GB  GDDR6X •  RAM» Corsair Dominator Platinum - 64GB DDR4 3200Mhz
• CASE: » DeepCool Matrexx 4F » •  MB:     » MSi GodLike Gaming X99 »»» LGA 2011-v3 •  CPU:    » Intel i7-6950x Extreme Edition - 10-Core @ 3.00Ghz •  GPU:   » MSi GeForce GTX 1070 Ti GAMING  - 8GB  GDDR5 •  RAM» Corsair Vengeance RGB Pro - 32GB DDR4 3200Mhz
That PSU looks like death with a fan.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
lol, I personally prefer the molex train on the back.
PSU Tier List | CoC
lol
Main rig on profile
VAULT - File Server
OptiPlex 7040M
The PSU's fan is upside-down btw :P it ain't a killer of a build. But I'm planing to get a new gear soon.
Cooler Master's COSMOS 2, FTW!
Mine is too hard too see (Black case black cables) But I recently got it too look pretty good unless you take the back cover off....
CPU: i5-4690K @ 4.0GHz GPU: Gigabyte Gtx 970 WindForce MOBO: Gigabyte Z97 Gaming-3 CASE: Corsair Carbide 200R PSU: Corsair RM750
RAM: Corsair Vengeance 4GBx4  MOUSE: CM Mizar KEYBOARD: Logitec G110
This build that I have was made in 2008. Then color matching the cables was not a big deal.
how my HTPC sits currently
Not bad mate.
Spent an hour (yes, an HOUR) tearing my setup apart and putting it back together to reduce the cable clutter and cable ugliness behind my desk. Well worth it. Before it was like a spider web and I had a ton of stuff at my feet. Now, it's clean and I have a lot less wires by my feet.
18479623514_24d7788d22_h.jpg20150623_214118 by Travis McClelland, on Flickr
18479623624_5002d61ec5_h.jpg20150623_214053 by Travis McClelland, on Flickr
18915988579_ee30042d0e_h.jpg20150623_214106 by Travis McClelland, on Flickr
Main rig on profile
VAULT - File Server
OptiPlex 7040M
-Snip-
See, that surge protector would go behind my desk. And yes, by something totally ghetto like tape but it would look MUCH better if it was behind the wood/metal thing above it.
Technically it is behind my desk. But I just got a new laptop to go with my trusty netbook (which will probably be a Minecraft server for my house) and my old Windows 98 laptop, so I have to have it accessible. It's actually not really in the way.
EDIT: And I have to keep it in arm's reach since my power sometimes isn't the most reliable.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
ah okay, that makes sense.
If I was in your situation, I would just go buy another surge protector and plug it in somewhere else, but ok. Makes sense  :D
