Okay so I bought everything now I only need the power supply and I really don't know which one should I get.
https://pcpartpicker.com/list/hjYqf9
https://www.corsair.com/us/en/Categories/Products/Power-Supply-Units/txm-series-2017-config/p/CP-9020132-NA
or
https://www.coolermaster.com/catalog/power-supplies/mwe-series/mwe-gold-550-full-modular/
I went to all those pcbuilding sites and I got around 480 in total of watt usage. On GPU official site it says I should use a 650w psu.
idk
https://linustechtips.com/topic/1208424-only-power-supply-left/
or
idk
I suggest this https://www.evga.com/articles/00971/EVGA-700B-Power-Supply/ because it's not that much more expensive than a 650 w and gives you some headroom to upgrade.
Sorry didn't see the psu you suggested so go for the 650 w corsair one
Edited by Smit Devrukhkar
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710091
You want a healthy margin between the power draw of your system and the rating on your psu. Both of those look fairly decent. Might as well go for the 650W
If you judge a fish based on its ability to climb trees it will go its whole life thinking its a failure.
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710095
550 should be enough.
corsair cxm550.
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710100
I'd get the TXM. 550W would be more than enough for that system, but if you can get 650W for the same price then why not.
Trading quality for 50 more unnecessary watts really doesn't sound like a good tradeoff to me.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710101
You are trading quality for watts. A 3950x and a 2080ti can run on a 450w. 700w is unnecessary.
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710107
If you overclock 450 would not be enough and not to mention, correct me if I’m wrong but if you run the psu near max capacity at all times doesn’t that shorten the life of the unit? Because if it’s ran at near capacity it’s running at near it’s max temp? Which heat = component life. If it’s only like a few bucks for a higher wattage I don’t see why he wouldn’t.
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710188
an adequately cooler power supply will not suffer when run near maximum capacity.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710190
Nobody will realistically pair a 3950X and 2080Ti with a 450W PSU - @gloop was just using this as an argument for the guy that suggested a 700W PSU instead above, not suggesting OP to get a 400W power supply.
Running a PSU at near full capacity definitely won't help with its longevity, though high-end units won't suffer as much from this.
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710217
1 minute ago, gloop said:
But my statement is correct. I said
I never said anything about overclocking any component.
Right, I wasn’t aware that kind of hardware could run through a 450 watt. Especially under load. On part picker are the wattage requirements really that off? Is 444 watts what his system will pull under heavy load or is it just overcompensating the fact people buy shit psus
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710220
That's definitely one of the reasons.
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13710226
Are you aware that you're suggesting low end 700W PSU instead if high end 650W one OP is asking about ?
Tag or quote me so i see your reply
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13712306
Sorry didn't see the psu op suggested
Desktop :
Laptop :
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13712365
UPDATE : I chose the Corsair 650 watt one, it has a single rail and I wasn't sure to get that one or get a multi rail PSU but since I won't be using the SLI GPU and I don't think I'm going to be in some heavy ass overclocking, I'll get the single one.
I'll make a new update in case anything explodes lmao
https://linustechtips.com/topic/1208424-only-power-supply-left/#findComment-13716261
