Looking for headphones for RIFT S
xReqt
Hey,
I am looking to buy some headphones for the rift s with a budget of 30 pounds.  I am unsure which would pair well with the VR Headset so I need some assistance.
Amazon UK only please.
Thanks in advance :)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
16GB DDR4 Crucial ram (2133mhz)
Prime Z370-A Motherboard
Gamemax Falcon (White)
Peripherals
Logitech G305
Corsair Strafe MX RED
Blue Yeti /w arm
JVC (Headphones)
Best audio you can get for any VR headset are the KOSS KSC75's. Amazing sound for the price and instead of actual headphones they have a clip design that rests on your ear.
3 hours ago, Onehandstander said:
Best audio you can get for any VR headset are the KOSS KSC75's. Amazing sound for the price and instead of actual headphones they have a clip design that rests on your ear..
No the best audio you can get that is actually built in is the Valve Index
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
Okay  KOSS KSC75 I will buy and give them a try.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
@Tigerleon Could you recommend any headphones for Rift S or do you agree KOSS KSC75 is a solid choice?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
The KOSS KSC75 Is pretty good yes. For VR it'll do.
AKG P420 Mic
Other peripherals
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
@Tigerleon Would really any headphones do? or is there limitations
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
On ear headphones can get uncomfortable, usual suggestions for VR are either over or floating away from the ears.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Not really but you don't really need to spend more than 40 dollars on headphones for a vr headset that isn't even using onboard audio or a good DAC.
AKG P420 Mic
Other peripherals
I am using an Oculus Quest with the official link cable and the sound is bad. It can't use the onboard audio since it is connected with a fiber optic usb type C cable to my motherboard or GPU. So there must be a built in dac somewhere inside of the VR headset. I'm planning on getting the Valve Index since it is much better.
AKG P420 Mic
Other peripherals
The Quest and Rift S are in completely different ballparks though, besides, you don't use VR for critical listening so that should really be a non-issue.
@rice guru
That's true I guess..
AKG P420 Mic
Other peripherals
