How long is the cable for the Blue Snowball Ice microphone?
UNBRUH_MOMENTO
I was wondering how long the cable was just to see if it will be compatible with my setup.
abt. 6ft from mine
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
Quick question, Why getting a Snowball yeti? It's 2020, there are better options.
Quick question, where did you read the word Yeti?
Can you recommend me a better mic 50 or under?
If you can find it for that price a Samson q2u
Or t.bone MB88U if you're in Europe, it's like the Q2U but cheaper and more available. AT2005 is in a similar boat.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
