I haven't changed the thermal compound on my CPU in 4 years (since I built it) and someone suggested I should probably replace it to see if it'll fix some CPU issues I was having (https://linustechtips.com/main/topic/1205293-cpu-lag-spikes/). I last used AS5 but I'm wondering if there are better alternatives now. My CPU is an FX-8350
Thanks!
EDIT: Heatsink is a Hyper 212 EVO
Red (Soon to be Retired)CPU: FX-8350 Cooler: CM 212 Evo  GPU: Gigabyte GTX 1060 6GB RAM: 16 GB Kingston HyperX 1866MHz Mobo: Asus M5A97 LE R2.0 SSD: Kingston 128 GB (Boot), Samsung 860 EVO 500 GB (Main Games) HDD: WD Black 1 TB (Storage + Older Games) PSU: EVGA W1 500W Monitor: Dell ST2220l 21.5". Peripherals: Razer Blackwidow Ultimate 2013 Keyboard, Razer Deathadder Mouse, SteelSeries mosepad,
https://linustechtips.com/topic/1206638-best-thermal-compund/
Top Dog right now is Thermal Grizzly Kryonaut. AS5 is still a decent paste, but far from the top anymore like it use to be.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13696170
I have a bag full of different little tubes of thermal paste, it really isn't a huge deal unless you're running high overclocks. Arctic Silver has been one I've used for many years so far. What cooler are you running?
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13696208
Hyper 212 Evo
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13696253
4 minutes ago, DGB said:
Hyper 212 Evo
If you have Arctic Silver laying around, and it's not really old, I'd try a re-apply and see if that doesn't help. Even with modern games at reasonable settings, FX is still getting it done. My brother is rocking an FX-8350/8GB 1600mhz/RX 480 4GB setup I built him a few years back, he plays Fallout 76 and we get a game of Minecraft going now and then.
AMD Ryzen 5900X
EVGA RTX 3060 Ti XC
WD 5400RPM 2TB
EVGA G3 750W
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13696282
The FX is highly underrated imo it's served me well. As for the AS5, I have it but it's been laying around for 4 years and I've seen that those compounds tend to expire after 3 years or so sitting on the shelf.
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13696290
You should probably get some new paste as even if it looks ok and taste fine it might be expired and won't lead to the best temps it could give you.
please don't taste it ...
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13703110
Thanks!
Kingpin KPx and thermal grizzly are neck and neck.
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13703576
I really like Thermalright TF8, very good stuff. At 13.8W/m.k its not their best, but its good enough for what I'm doing.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13705043
The top dog right now is Thermaright TFX, but I'm unsure how it compares to the Kingpin KPX and that other popular subzero paste.  I've tested it side by side on TWO coolers on two different 10900k on two different motherboards.  NH-D15 and 360mm AIO.  Versus Kryonaut, about 2-3C better temps after curing a few days.  I have 150 grams of homemade Galinstan LM, two syringes of Kryonaut (one's almost gone), some NT-H1, Coolermaster Gel Maker Nano, MX-4 (old 2012 version) etc...even some really old Ceramique I used as a 'dam' for liquid metal..
https://linustechtips.com/topic/1206638-best-thermal-compund/#findComment-13707677
